www.KitGuitarsForum.com
It is currently Fri Jun 22, 2018 10:46 pm
Post new topic Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Fri Oct 13, 2017 4:48 pm
Offline
Anyone have any tips or tricks for getting enough heat in a Martin square tube rod to get the epoxy to release for removal?
Top
 Profile
PostPosted: Fri Oct 13, 2017 6:25 pm
Offline
why are you taking it out?
_________________
Top
 Profile
PostPosted: Fri Oct 13, 2017 6:39 pm
Offline
Conversion to adjustable rod.
Top
 Profile
PostPosted: Fri Oct 13, 2017 9:01 pm
Offline
heat
try a heat lamp wrap aluminum foil around some cardboard and expose the rod protect the neck and let heat do the job
_________________
Top
 Profile
PostPosted: Fri Oct 13, 2017 9:05 pm
Offline
Good idea, John. I used to do all my heating that way, but the blankets have spoiled me.
Thanks!
Top
 Profile
PostPosted: Sun Oct 15, 2017 6:46 pm
Offline
this is what you need I dont have a blanket for that LOL
_________________
Top
 Profile
PostPosted: Sun Oct 15, 2017 10:42 pm
Offline
Could you post a picture? Would like to see what you have going. Do you have access to the interior of the tube?
_________________
Measure Twice,
Karl B
Top
 Profile
PostPosted: Mon Oct 16, 2017 6:41 pm
Offline
yes but it is about 14 in long epoxied in
_________________
Top
 Profile
PostPosted: Mon Oct 16, 2017 8:12 pm
Offline
Thinking out loud- a 12v car battery connected across the length would turn a metal rod RED hot, so I’ve been told. It will turn a ratchet Handle into a 1000 watt heater. AC house current, in series with a incandescent light bulb would also turn it red hot and not blow the breaker. A variac could be used to control the heat dissipated by the rod. An AC Heater element ( just for the load, not the heat) could be used in series with the rod. Just thinking, use the truss rod itself as the heat source. This would also be dangerous and unsafe in an uncontrolled environment. Don’t try it at home.
_________________
Measure Twice,
Karl B
Top
 Profile
PostPosted: Mon Oct 16, 2017 8:54 pm
Offline
too much heat
glue will fail about 145F
charring the wood is the last thing you want to do.
Yes a car battery will make it hot but you cannot control it
_________________
Top
 Profile
Who is online
Jump to:
