www.KitGuitarsForum.com
It is currently Wed Jul 18, 2018 6:55 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Neck reset
PostPosted: Mon Jul 22, 2013 10:35 am
Offline
How many times can the neck be reset by flossing the cheeks before the angle becomes too much and creates a hump at the body joint??
Top
 Profile
 Post subject: Re: Neck reset
PostPosted: Mon Jul 22, 2013 12:08 pm
Offline
Often times when doing a neck re set you will need to shim the fret board extension so it follows the proper plane. As long as that its done there should be no issues with a hump or dip and the procedure can be done many times if needed.
_________________
Top
 Profile
PostPosted: Sat Oct 19, 2013 8:07 am
Offline
What Howard said, it isn't that you will get a hump as much as the extension will stay flat on the top and the neck will be hinged back. If this is a customers instrument I will be sure to communicate to them. If the fall off is noticeable I like to wedge it so the extension is true to the neck.
_________________
Top
 Profile
Who is online
Jump to:
