Bending question
Bending question
I've seen posts on using a small amount of fabric softener or windex, to bend some woods. How do you use each of these? Is one better than the other?
Re: Bending question
having used all 3 I feel the windex with ammonia D is the easiest to use.
super soft 2 water stains the wood and is the most costly
fabric softener you have to find a mix that works also leaves a perfume smell behind
windex comes in its own spray bottle and works without smell or water staining
Thanks!
Post by nkwak »
I just used Windex on some flamed maple binding. It worked like a charm.
dave66
Post by dave66 »
tippie53 wrote:having used all 3 I feel the windex with ammonia D is the easiest to use.
Just starting my second guitar build and first time bending. Is the technique to spray the windex on my rosewood sides just prior to bending or soak them in it for a while?
Thanks very much, David Snowdon
Rag Thumb
Post by Rag Thumb »
I would highly recommend you look at John's most recent Youtube video on bending and not take it from me, but I believe the technique is to spray the Windex on the wood as well as on a paper (Kraft or other) but not to the point of soaking. Definitely do not need to soak the wood. During the bending process John also rechecks under the metal sheets to make sure the moisture hasn't totally evaporated.
Rex
we are shooting new video in a few weeks and will post links here
bending is on the list
