www.KitGuitarsForum.com
It is currently Thu Jan 21, 2021 11:10 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: finishing prep
PostPosted: Mon Jun 10, 2019 7:42 pm
Offline
I have been doing a good bit of finish experiments lately as you well know and here is a primer I would pass on
I have pics that will come soon but let me help you newbies how you can help yourself and make a good finish with simple techniques.
I am making a guitar for a charity so this is a great candidate for this experiment. I will be using water finish emtec water based lacquer.
The body is all mahgany 000 15 body that was donated by Martin. I sanded this to 180 grit. To that I then stained using minwax English Chestnut. After staining I sealed with shellac. After that dried I then applied Aqua Coat . I used 2 applications using a gloved hand to work it in then wiped it off with paper towels. That is now drying and I will get pics tomorrow and will keep you all posted on the progress.
I am also using a high figured hog neck so I can see if there is any differences in figure and non figure. So far I have about 2 hr total between sanding , staining , and filling. I am pleasantly surprise of the flatness of the surface and will expect a super gloss when buffed. I will let you know the exact finish I am using as I apply it
_________________
Top
 Profile
 Post subject: Re: finishing prep
PostPosted: Sat Jun 15, 2019 7:12 pm
Offline
Thanks John for taking the time to do the work and posting these tips and experiments...
I will be waiting patiently to see your results.
-Patrick
Top
 Profile
PostPosted: Sat Jun 15, 2019 11:16 pm
Online
Most interested in techniques involving staining and light binding/purfling. I'm at a loss as to how to deal with stain contaminating purfling and/or bindings.
Thanks!
_________________
Top
 Profile
PostPosted: Mon Jun 17, 2019 6:24 am
Offline
scraping
I use a razor blade and grind the side like a scraper , using my fingers as a guitar I can scrape them clean. You can also try masking off the the binding but I learned scraping was the way to go with the plastic. On wood. I do mask wood off and shoot it with a few coats of clean then stain.
_________________
Top
 Profile
PostPosted: Mon Jun 17, 2019 9:51 am
Online
Thanks, John.
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Jump to:
