Neck has Rise at Body Joint
Re: Neck has Rise at Body Joint
Will a picture show the problem? Seeing helps.
I agree with Dan, picture is essential - could be a few things
The neck geometry appears to be slightly off; the fingerboard plane seems to cut into the bridge or at least that's my take on the photo. Is the sides/heel joint still tight? The truss rod would adjust for relief bowing, but i wonder about whether it would do much here.
Hide glue had nothing to do with this
here is a video
https://www.youtube.com/watch?v=FNcbA1P95KE&t=15s
I would say you missed a step in the neck setting process or you have a serious humidity issue
had you done the proper steps , and it was straight , then you may have had a swing in the rh this will make a rise in the top. In sever RH swings it can lift the upper part of the top
here is a video
Mike,
If you placed a straight edge on frets 1-13, it looks like your FB is straight. If you extended the straight edge to fret 22, to keep on the frets 1-13 it would have to cut thru the FB extension frets coming to the bridge below the saddle. In addition to losing some upper range frets, your saddle would need to eventually get lower. The fix is a neck reset (John can confirm that or indicate another remedy). The good news is that getting this right will add to your experience regardless of the approach taken.
feel free to call me
also get a good hygrometer and know your RH at time of build and current it saves a lot of issues
that is not your problem as the moisture will come down in a few days
I suspect that the top is swelled from RH or you missed the neck set
pulling a neck isn't that difficult
here is a link
https://www.youtube.com/watch?v=RurSR88jc8s&t=7s
here is a link
