www.KitGuitarsForum.com
It is currently Thu Dec 13, 2018 8:06 am
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Wed Jul 19, 2017 11:12 pm
Offline
I'm about to glue on the top having dry fitted several times.
What do you guys treat your cork with ( on both spool faces) to keep glue from sticking to it? I can see it enevitable that's going to happen, and I'd rather not ruin the cork faces if there is a great home grown release agent so glue gloop is easily removed without tearing the cork. im thinking a little jojoba oil or pure carnuba wax? Anything on the cork will transfer to the wood, so its it's a serious matter : )
_________________
Measure Twice,
Karl B
Top
 Profile
PostPosted: Wed Jul 19, 2017 11:50 pm
Offline
Wax might work, but you don't want slippery
Top
 Profile
PostPosted: Thu Jul 20, 2017 6:36 am
Offline
Wouldn't most of the squeeze out be below the cork face? A neat, but sufficient, application of glue might be useful - clean up can be a challenge around spool clamps. You might consider green tape all around the top to prevent the top from getting cork marks.
Top
 Profile
PostPosted: Thu Jul 20, 2017 10:59 pm
Offline
Embrace your fears:
_________________
Measure Twice,
Karl B
Top
 Profile
PostPosted: Fri Jul 21, 2017 9:05 am
Offline
Nice! I like the oval spools; gives the opportunity for a little more holding area. With the glued edge down, I understand your concern for the squeeze out glue running onto the spools.
Top
 Profile
PostPosted: Fri Jul 21, 2017 11:25 pm
Offline
Like you said, an efficient application of glue was a fine solution. That was not a "fun" tsk either.
_________________
Measure Twice,
Karl B
Top
 Profile
PostPosted: Sat Jul 22, 2017 2:01 pm
Offline
It seems to me that waxing the clamps would discourage glue binding for any type of glue.
Top
 Profile
PostPosted: Sun Jul 23, 2017 9:34 am
Offline
I'm going to try wax on a couple and see how a slick surface works on the radiused back. I'll be glueing the back this week after I cut the pockets for back braces. Oh, and glue on the side strips - there's always one more thing..... : )
_________________
Measure Twice,
Karl B
Top
 Profile
PostPosted: Sun Jul 23, 2017 10:02 pm
Offline
I would try wax on a scrap of wood first, to see if it makes it glue proof, before using it on anything important.
Top
 Profile
PostPosted: Thu Jul 27, 2017 8:47 pm
Offline
True, but I don't use anything because I don't want the wax (or oil, or whatever) to come in contact with the wood itself. Cork is cheap ... you can buy it in sheets at most big-box office stores and cut it to whatever size you need. I also use it for my cam clamps. If it ever gets ratty, I just cut it off and replace it.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Jump to:
cron
