When to Dye Back/Sides/Neck?
Re: When to Dye Back/Sides/Neck?
Thanks Ed,
Did you do the lighter colored dye first, or Darker?
Glenn
Glenn
On the body I did brown first then a bit of red. The neck was darker to begin with so I did a little brown, a little red, and added some brown and the colors turned out pretty close.
Your sunburst looks great
Started on the White Oak B&S of the Grand Concert Guitar. I first applied black dye, then sanded off, then put on some colors and improvised till I got the colors I wanted - used a combo of med brown, Brown Mahogany, and a couple drops of red.
This only has 1 coat of sprayed shellac to lock in colors. I tried to apply with Alcohol this time, instead of water. working time was a bit shorter, but since I wasn't doing the sunburst, I didn't really notice a bog difference - but no grain raising which is nice. got dome dye on the surfings, and need to scrape. Luckily, I applied shellac to all the purflings prior to taping, so I am hoping they clean up easily.
GlennYou do not have the required permissions to view the files attached to this post.
First Impressions of Aqua Coat for Pore Fill:
Aqua Coat seems to work pretty easily. Very little smell (Z-poxy bothered me), spread easy, sanded nicely, and for the 2 guitars - Cuban Mahogany and White Oak - seemed to fill nicely. After 3 applications (dries fast, so I did all 3 today), the cuban Hog is good to go. I will do 1 more on the cavernous pores of the White Oak. I applied with a soft cloth and just rubbed it in.
Once i have it done, and put a deal coat of shellac over it, I will send pics. I plan to use tru oil on the back and sides, and French Polish the tops.
Thanks,
Glenn
Thanks,
Glenn
Update. After 9 sessions with Tru Oil on Back and Sides (going to French Polish tops):
Glen
The oak instrument looks fantastic (other one too!) How many coats of tru-oil? did you sand or steel wool between coats?
Can I get some of your purfling material?
HI Ed,
Thanks! So far, 9 coats. I usually aim for 12-14 coats, then after the tru oil cures for a couple weeks I buff out with Micro-Mesh grade 3000 up to 12000. After 4 or 5 applications, I gently rub with 0000 wool to level.
I actually do have a bunch of the purfling material - I ordered it through Gurian, and exactly designed it using their design tool to look like my 1925 Joseph Neptune Grand Concert. I can ship you an instruments worth if you would like? I think I gave John a few instruments worth. I also got some nice marquetry inlays from here:
http://www.inlays.com/category-s/1938.htm
The purfling I have is in 3 pieces. 2 bl/wh dentile pieces, and then the middle rope (I always loved the green form my Joseph Nettuno.
Here are some close-ups:
Here is a close-up of my 1925 Joseph Netunno My Guitar: Glenn
After some business travel in Europe, was able to finish the neck prep for dye as well. I should have done this at same time as body, but was too gung ho to get the bodies done :-). I kept my notes, so I should be able to match. I will do a subtle sunburst on back of the neck to match the back.
Finished shaping the neck - just need to sand to 220. Front with Mad RW Fingered and Headstock overlay. Mock-up of what the guitar will look like. only have a shellac coat on top to protect it. I will be French Polishing the top, Tru Oil on the neck (I love the feel of Tru Oil on necks as a player). Still need to trim the fingerboard to length (also still have tape on top for where fingerboard goes, so neck isn't centered on the body - just a quick mock-up) Glenn
Dyed the necks. I think I got pretty close wrt colors, etc. Just a spray coat of shellac to lock in the colors. got blotchy in some places. Spraying the shellac is a sensitive thing, as too much, and it will bleed the dye before setting.
Completed 3 French Polish sessions (each session is 3-5 applications), 2 leveling, and 2 spiriting off sessions per Robbie O'Brien's FP method. Essentially, top is done, just need to maybe do another sprit off if any residual oil is still on top. Pic gives an idea of the sunburst under finish.
Glenn
Thanks,Glenn
