If you do not file the string groove then what keeps them in place?Ben-Had wrote:As you are looking at the picture the High e is on the left, Low E on the right. Here's how I do it. 1.) String it up, 2.) Tune to pitch, 3.) check/set the neck relief, 4.) check the strings for proper height over the 1st fret (I set mine starting the high e at .014 over Fret, then increase by .002 up to the Low E at .024), 5.) check height of strings over the 12th fret and adjust the saddle as necessary (for every 1/64 at the 12th you want to lower it, you have to take off 1/32 on the saddle and visa versa using shims to raise it, although I hate shims and never use them, I prefer to cut a new saddle). ALSO, DO NOT "file the string grooves," (unless you're talking o the nut) at least that's me. Os that somewhat what you were looking for?David L wrote:Here's the saddle as it came in the kit. Notice that one end is .370" and the other end is .305, is this supposed to be like this and if it is, which end goes at the low "E" end and which end goes at the high "E" end. I am ready to install the saddle, what is the procedure? Do I install it as it is, file the string grooves and then make some kind of string height measurement and then start making adjustments? What would the desireable string height be? Where would the string height measurements be taken? What is the meaning of life?
Blogging Fatso!
Re: Blogging Fatso!
The box of Martin strings that came with my kit lists: E-1st silvered steel at .012" and E-6th bronze wound at .054". Which one is the high "E" and which one is the low "E"?
Re: Blogging Fatso!
You file grooves in the nut, but not in the saddle. At the saddle end they are close enough to the pins that they won't move side to side. The depth of the slots in the nut need to be deep enough to keep the strings in place during bends, etc...
The .012 is the high E.. the smallest (highest pitch) string.
The .054 is the low E (lowest pitch).
Re: Blogging Fatso!
Well I strung it up and I'm so frustrated I'm about to wrap this son-of-a-bitch around a telephone pole!!! First I broke the "D" string and I can't even figure out how to use this piece of $h1+ tuning thing, the directions are practically useless and don't give enough information for it to make any sense to me.
Re: Blogging Fatso!
It is a chromatic tuner, so as you pluck the string and turn the tuner you should see the note lights moving up the alphabet and back around.
You can hear what each string should sound like plucking the virtual strings on this web site.
http://www.guitarforbeginners.com/onlinetuner.html
Tune each string while plucking until it sounds like the guitar on the web site. Watch the tuner while you are doing it. You should see the notes progress up the alphabet as you tighten the string. When it is close to what you hear on the web site and reading the correct note and the green light is on between the b and # and the green light next to the # is off the string should be in tune.
When the D string broke you probably were tuning up to the next higher D.
Re: Blogging Fatso!
+1 :)Jim_H wrote:You file grooves in the nut, but not in the saddle. At the saddle end they are close enough to the pins that they won't move side to side. The depth of the slots in the nut need to be deep enough to keep the strings in place during bends, etc...
Re: Blogging Fatso!
David just remember a chromatic tuner only recognizes the note not the octave so to it a "D" is a "D."johnnparchem wrote:It is a chromatic tuner, so as you pluck the string and turn the tuner you should see the note lights moving up the alphabet and back around.
Re: Blogging Fatso!
Hang in there David. I've done exactly what you did.
You'll get the hang of it soon where you can get them pretty close without needing a tuner.
I usually have a tuned guitar in the area and will pluck a string for some reassurance that I'm in the ballpark.
BTW, if you have a smartphone, there are some really good tuner apps available. I have an android phone and use a tuner called gStrings. It used to be free but it might cost a buck or two now, but dang it's really good. I use it for about 90% of my acoustic tuning needs. And because it's my phone, it's usually handy...
The nice thing about it it's an analog style display ( a needle just like on the old fashioned tuners). You can set it to tune a specific note, or tune chromatically.
Might be worth looking in to.
Re: Blogging Fatso!
Thanks Jim but I do not own a smart phone, don't want a phone that's smarter than me. I tried John Parchem's link and did manage to have "some" success. Now I need to get some feeler gauges and get the string height set. Oh yeah, I also need to buy a new set of strings so I can replace that broken "D" string (patience, patience, patience).
Re: Blogging Fatso!
For anyone interested who happens to have an android phone or tablet, here is the market link to the gString tuner I was talking about.
https://market.android.com/details?id=o ... ings&hl=en
Looks like there is a free version and a paid version they are charging $2 for. I have the paid version. Not sure what the differences are.
Unfortunately for the Apple Sheeples, it doesn't look like there is an iPhone version. :p
Re: Blogging Fatso!
Thanks guys for being patient with me through this frustrating portion, I somehow thought that I was going to have problems at this stage. (so close, yet so far away)
