www.KitGuitarsForum.com
It is currently Tue Jul 14, 2020 5:53 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
 Post subject: Re: birdhouse project
PostPosted: Tue Feb 06, 2018 10:24 pm
Offline
I clamp my router in the vice with 2 fitted pieces of wood. Usually I pass the router over the body, but I will try to pass the body over the router.
Just takes a minute to spin the body - then a second time to ensure everything is even
Top
 Profile
PostPosted: Tue Feb 06, 2018 10:29 pm
Offline
Here is am holding the body against the tall fence as I spin it. This technique works great and I will try it on my next guitar.
Tape on the binding
A friend came up with a name for the project
The Bluesbird House
Does anyone know how to post more than 3 shots per message? Or more than one URL?
Top
 Profile
PostPosted: Wed Feb 07, 2018 4:07 pm
Offline
Scrape the binding. I normally let the Duco sit for a bit as the binding shrinks, but it will still look great on this one
Make a bridge - saw the slot for the saddle - which in this case is a piece of ivoroid binding,
Top
 Profile
PostPosted: Wed Feb 07, 2018 4:08 pm
Offline
Glue on the bridge
Glue in the saddle
Top
 Profile
PostPosted: Thu Feb 08, 2018 1:13 am
Offline
Do you change the setting of your router bit to take a tiny bit more off when you go around a second time for the binding? Or do you just go around the second time to get any spots you missed?
Top
 Profile
PostPosted: Thu Feb 08, 2018 3:44 pm
Offline
2 passes with the same setting. On a real guitar I might do 3 to be sure. I have never had to do much filing to even things up.
Top
 Profile
PostPosted: Fri Feb 09, 2018 12:52 am
Offline
Url's are limited. I've not had any issue with posting photos. I don't know if you're limited by the size of the photos.
Are you putting your photos directly into the forum, or are you using a hosting service, like photobucket? You may be limited to 3 per post if you use a photo service.
Top
 Profile
PostPosted: Fri Feb 09, 2018 3:43 am
Offline
I am restricted to three uploaded photos per post. I don't think this is unreasonable, but I wanted to give Ruby some confirmation that it's not just them.
Top
 Profile
PostPosted: Fri Feb 09, 2018 12:21 pm
Offline
All that's left is a set of legs to stand it up for display - I will eventually bolt it to a fencepost. I will add a picture once it goes on display in early March.
All walnut (thanks Diane), except for the piece of pine that is the pole/neck
Top
 Profile
PostPosted: Fri Feb 09, 2018 12:23 pm
Offline
And a couple more. If I post from a service, there is a URL involved and I only get the one to list. If I post pictures from my desktop, then I only get 3.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Jump to:
cron
