www.KitGuitarsForum.com
It is currently Sun Jul 15, 2018 7:18 pm
Post new topic Reply to topic  [ 7 posts ]
Author Message
PostPosted: Thu Mar 02, 2017 9:20 pm
Offline
Okay, the newbie cannot plane the edges of the figured maple he planned to use for the back of the tenor ukulele. Randy says sanding is the best option. I came up with an idea after seeing that Veritas (Lee Valley) has a sanding plane and shooting board setup for more money than I'm interested in spending.
Has any one tried sticking sandpaper to the bottom of a hand plane with spray on adhesive and using that with a shooting board? I've a Lie Nielsen low angle jack plane that is about 14" long. Randy says start with 100 grit and work up to 320. Tedious but do-able, particularly when one has more time than experience...
Thanks again for your experience and wisdom in this!
Top
 Profile
PostPosted: Thu Mar 02, 2017 11:06 pm
Offline
The level in the photo below has sandpaper stuck to the edge. It works well for me.
_________________
- Randall Newcomb
Top
 Profile
PostPosted: Thu Mar 02, 2017 11:13 pm
Offline
To true up for jointing I use a piece of 1"aluminum (about 30") angle screwed to a piece of mdf 30"x12". Cut adhesive backed sandpaper to fit the angle. Run the back or top pieces in one direction only. Check fit frequently. When you're close you'd be surprised how little pressure it takes to make a change.
_________________
Learning every day.
Top
 Profile
PostPosted: Fri Mar 03, 2017 1:58 am
Offline
Chuck, yes. I plane first the put paper on the plane and lightly sand the jointed edges. This works for me even better than paper on the level, which I have used often too.
Top
 Profile
PostPosted: Fri Mar 03, 2017 10:48 am
Offline
MUCH simpler than the plane idea! Plus, the sandpaper doesn't stick to a waxed plane sole too well... :)
Top
 Profile
PostPosted: Fri Mar 03, 2017 10:49 am
Offline
Great tips, John! Thank you. :)
Top
 Profile
PostPosted: Fri Mar 03, 2017 10:51 am
Offline
Thanks, Kevin. I had waxed the sole of the plane. I'd have to do something about that first, but it's encouraging that you've used this method.
Top
 Profile
Who is online
Users browsing this forum: colmac, ruby@magpage.com and 3 guests
Jump to:
