www.KitGuitarsForum.com
It is currently Mon Jul 23, 2018 3:45 am
Post new topic Reply to topic  [ 14 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Sat Feb 18, 2017 11:31 pm
Offline
I bent the sides for a J45 with Peruvian Walnut back & sides. I'm very pleased.
_________________
- Randall Newcomb
Top
 Profile
PostPosted: Sat Feb 18, 2017 11:47 pm
Offline
Hey Randall great job. A good feeling huh.
I bent by had for my first 5 guitars, I remember how pleasurable it was, but took some work too.
Top
 Profile
PostPosted: Sun Feb 19, 2017 11:11 am
Offline
it is a good skill to have nice work
_________________
Top
 Profile
PostPosted: Sun Feb 19, 2017 11:32 am
Offline
Great fun and a valuable skill. Good job.
Top
 Profile
PostPosted: Wed Feb 22, 2017 9:36 pm
Offline
Good job!
Top
 Profile
PostPosted: Thu Feb 23, 2017 11:08 pm
Offline
On looking at the picture of your iron, I think you might get slightly better performance from it if it were cleaner. Get the resin off of it with a green scrubby or steel wool.
Top
 Profile
PostPosted: Sun Feb 26, 2017 2:14 am
Offline
A green Scotch Brite pad and some water cleaned it right up.
_________________
- Randall Newcomb
Top
 Profile
PostPosted: Fri May 12, 2017 12:45 am
Offline
May I ask how you heat it? I have one a friend made from a piece of boat mast. It has a 300 watt lamp inside but in my limited experience I don't think it gets hot enough. I found it better when I also directed a heat gun at it but that gets a little crowded. I've found trying to figure out what sort of heater to use as an alternative quite confusing.
Top
 Profile
PostPosted: Fri May 12, 2017 12:49 am
Offline
I bought it on eBay. It came from China and I assume it has a heater inside. It take some time to come up to temperature.
_________________
- Randall Newcomb
Top
 Profile
PostPosted: Fri May 12, 2017 10:20 am
Offline
I use a 6x6" heat blanket on top of the pipe and then I wrapped a sheet of copper (it's what I had on hand) around the blanket/pipe. It works quite well.
_________________
Learning every day.
Top
 Profile
Who is online
Jump to:
cron
