www.KitGuitarsForum.com
It is currently Wed Oct 17, 2018 1:16 pm
Post new topic Reply to topic  [ 5 posts ]
Author Message
PostPosted: Wed Jul 26, 2017 9:24 pm
Offline
1. Band saw
2. Drill press
3. Table saw
4. Drum sander
5. Spindle sander
6. Disc/Belt sander
7. Jointer
8. Router table
What am I missing?
I was able to acquire a 22/44 Drum sander which was the one tool I thought was totally out of reach. I have an old drill press but am not sure it's up to the task in accuracy, it's probably 70 years old and built like a tank. Got burned on a 1966 Delta Band saw last week. I thought it just needed new bearings on the lower wheel but it turned out to be a destroyed drive shaft.
Top
 Profile
PostPosted: Wed Jul 26, 2017 9:38 pm
Offline
Good list. Some of these vintage machines/tools found in garage/estate auction sales are incredibly good values; well-built, repairable and inexpensive. Carefully selected Harbor crate tools can be good tools as well. How do you like your 22/44 sander?
Top
 Profile
PostPosted: Wed Jul 26, 2017 10:12 pm
Offline
kinspeed wrote:
1. Band saw
2. Drill press
3. Table saw
4. Drum sander
5. Spindle sander
6. Disc/Belt sander
7. Jointer
8. Router table
What am I missing?
Japanese dozuki saw- I use it WAY more than bandsaw. Become one with dozuki.
_________________
Measure Twice,
Karl B
Top
 Profile
PostPosted: Thu Jul 27, 2017 6:10 am
Offline
Tell us more. I've run across dozuki luthiers for 40 years -- gotta be something to them. Dozuki cut on the pull stroke and come in different kerf widths, etc.?
Top
 Profile
PostPosted: Thu Jul 27, 2017 6:24 pm
Offline
Dozuki saws are really great. They differ from some other Japanese pull saws because of the hard spline back. That makes the blade stiff and able to cut extremely straight for things like dovetails. The spline back does limit the depth of cut, so knowing what you want it for is important when you buy one. I don't think a blade length of less that 8-9" is worth buying. The little Dozukis don't work for me.Full size saws are cheap, costing $40-$50 for a good one. If you buy one that has replaceable blades, you'll spend about 1/2-2/3 of the price of a new saw when you decide to replace the blade. Lots of uses around the shop. If you have not used a Japanese pull saw, you will be amazed. There is no learning curve involved.
Top
 Profile
Who is online
Jump to:
