www.KitGuitarsForum.com
It is currently Mon Oct 22, 2018 1:48 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Mon Oct 24, 2016 12:45 pm
Offline
I picked up this plane this morning. I don't know anything about these planes. It looked complete but I did notice an open screw hole on the side.
Marked made in usa, but I don't see any other marking other than the iron is marked "Craftsman" inside an oval.
Ed, can you tell me anything about this plane?
Top
 Profile
PostPosted: Mon Oct 24, 2016 4:57 pm
Offline
Best I can find so far is was made by Sargent before 1948 and if that is the original iron, then it was made for Sears.
Worth the $20 I paid for it, it will be fun to play with and use.
Top
 Profile
PostPosted: Mon Oct 24, 2016 11:05 pm
Offline
Yes that's a Sargent. The give-away is the little horn at the front for the web of your thumb to rest on. The three big guys all made tools for Craftsman/Sears - Stanley, Sargent, and Millers Falls. It should have a knicker under the depth stop on the right side - looks like a 3-leafed clover. It is used for cross grain work, dadoes, where the little blade scores the cross-grain for a clean cut. You sharpen the three sides and spin the knicker as you need it or not. When you sharpen the knicker, don't touch the outside edge, just sharpen the inside edge to be sure the thing cuts the correct line. I suggest a touch of lock-tite on the fence rod's threads, then use a nail or an awl to tighten the rod down - there is a hole in the end of the fence rod. Nothing more frustrating than to have the rod come loose while you are using it and the fence starts to flop around. Good find
Top
 Profile
PostPosted: Tue Oct 25, 2016 10:46 am
Offline
I looks like a previous owner cut down the top of the iron and made a screw driver tip
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Jump to:
