Time to build a GoBar deck
hummingbird
Yup, its that time. Here's the one I made. I used PVC tube, dowels and springs for the rods. 1" MDF for the base and top and threaded rod for the 4 posts.
Alain
mjmeehan
Re: Time to build a GoBar deck
A different take... very cool. Do you get the pressure you need?
mjmeehan
And I love that back... looking forward to seeing the finished pics!
hummingbird
The pressure is not to shabby. The springs are pretty strong. The travel is only about 1.75" though so I'll have to have different length dowels for different jobs. Also I would like to find some rubber caps or something for the ends to protect the soft brace wood from denting.
Alain
Tim R
I like the ingenuity. Keep i mind you will get increasing force with increasing compression. With the bent stick method the force does not seem to increase that much as the stick is bent more, but I haven't really tested that. -Tim
Valleyisle
Hi I'm new here but got an idea that I used. I coated my tips with "hot glue" in the flat shape of a hollow point bullet and the grip is rubbery soft enough (pending the pressure) to do a good secure grip without denting the piece. Hope it works for you.hummingbird wrote:The pressure is not to shabby. The springs are pretty strong. The travel is only about 1.75" though so I'll have to have different length dowels for different jobs. Also I would like to find some rubber caps or something for the ends to protect the soft brace wood from denting.
hummingbird
Good idea Valley with the hot glue but I'm afraid I don't know what a hollow point bullet looks like. You see I'm Canadian. :)
Alain
I bet you could also glue 1/4" cork to the ends....might work well enough. Otherwise, I bet if you wrapped tape around the ends, leaving 1/8" or 3/16", you could fill with hot glue, then remove the tape when it cools. I like the spring idea, though it is probably a little more expensive than others.
