www.KitGuitarsForum.com
It is currently Wed Jul 18, 2018 12:43 pm
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Dremel bits for inlay
PostPosted: Fri Sep 24, 2010 11:41 am
Ok,
I'm sure this has been asked a thousand times but I was wondering what bits you are useing for inlays. I don't want to spend the big bucks for the stewmac downward spiral bits. I was wondering what you use and were to get them. I was hoping to just pick some up at a local hardware store or ebay.
Thanks,
Aaron
Top
PostPosted: Sat Sep 25, 2010 3:38 pm
Offline
http://bqtool.com/cart/index.php?cPath= ... 54cdddab21
I use 1/32 square end mills and if you call them you can order .020 . At the price there are about 1/3rd the cost of Stew Mac
_________________
Top
 Profile
PostPosted: Sat Sep 25, 2010 6:06 pm
Correct me if I'm wrong but aren't those up cut bits? Down cut bits minimize tear-out risk which is why I prefer them. Upcuts work fine but there is a small risk of tear out especially when the bit gets dull.
This site has downcuts for about 1/2 the price of stewmac but they have a $50 minimum. http://www.precisebits.com/products/car ... 2flute.asp
There is also an ebay seller with a 5 piece set of downcuts from 1/8" - 1/32" for $59.95 plus shipping.
Top
PostPosted: Sun Sep 26, 2010 6:45 am
Offline
tippie53 wrote:
http://bqtool.com/cart/index.php?cPath=22&osCsid=ba1c6cad3618af10c4ac6e54cdddab21
John,
Do you have a special collet for the .020 bits or do they have a .125" shank?
Got any free/discount shipping codes for BQTOOL? Their minimum shipping and handling charge is out of line for a few micro bits.
I have these .125" 2 flute endmills http://www.grizzly.com/products/1-1-2-Solid-Carbide-End-Mills-1-8-x-2-Flute/H0941
in my Grizzly shopping basket but have no idea what kind of cut they will give me. For $7.95 each along with all the other stuff I need it's worth a gamble.
Top
 Profile
PostPosted: Sun Sep 26, 2010 7:20 am
Offline
I do not use down cut bits . A downward cut pushes the chips down and into the work. At this price you can replace them when they get dull. David Nichols of Custom Pearl Inlay , CF Martin , Tracey Cox, they all use the up cuts . The most important thing is to use a sharp bit.
_________________
Top
 Profile
PostPosted: Sun Sep 26, 2010 7:34 am
We (KMG) get our fine down spiral bits from a place called "Drill Bit City" you have to get to their commerical page or sometime Email them for availabilty -- very reasonable price. I've used the bit John recommends and the are excellent. However, I prefer the down spiral with the lower RPM of a router 16,000-23,000. I believe Johns air tool is over 60,000.
Top
PostPosted: Sun Sep 26, 2010 2:24 pm
That is exactly how I do it. Down cut with lower RPM's. I find the lower RPM to be easier to control and makes me work a little slower/more carefully. A high speed tool is just too easy to "get away" and do a lot of damage very quickly. Low RPM's can't cut nearly as fast which can be a big deal if you slip! I like down cuts exactly because it pushes the debris down. That keeps the edge clean and any potential chipping gets pushed downward, not up which in turn minimizes the risk of a nasty tear out. I suppose with a high speed tool though, the chance of chipping or 'fuzzies' are minimized with a sharp bit.
The big positive in using up cuts is that they are much easier to find and usually are quite a bit cheaper.
Top
PostPosted: Sun Sep 26, 2010 2:32 pm
Offline
I do use a pencil die grinders . One spins at 56000 rpm and the other at 70000 , this gives you more control and very clean cuts.
_________________
Top
 Profile
PostPosted: Wed Sep 29, 2010 8:38 pm
Thank you all for your advice.
Aaron
Top
Who is online
Jump to:
