I've reached the point where I need to sand the kerfed braces on the guitar top and bottom. The instructions tell me to construct a "sanding stick" to sand the kerfed braces to the proper angles at the top and bottom. They ask me to glue a 1.5 degree wedge on one side of the stick and a 5 degree wedge on the other. What is the best way to saw these? I have a table saw and a band saw, but I can't find a way to do it and be confident that I have the correct angles. Suggestions would be appreciated, including the possibility of buying them from some source.
Thanks,
Harold Hyatt
Sanding Stick for Stew=Mac Dread
Re: Sanding Stick for Stew=Mac Dread
Hello Harold.
I "traced" the front and back braces onto a long 2 X 2 piece of wood to make my sanding stick/glue cauls. It seemed to work well. I am not sure the best way to get the exact angle except for maybe tracing a 1 1/2 and 5 degree line on over sized pieces of wood and rough cutting them with your band saw then sand to the line. Then cut these into workable sanding tools. Good luck!
I did the same as Rich. I traced radius of the front and back braces on to a 2 x 4 and cut out the profile with a band saw. I'm just getting ready to attach the back and top so I hope it worked!
I cut the wedge from a 10" piece of 2x4 using a "table saw taper jig". My saw couldn't cut all the way through, so I cut about 1" deep on both edges then finished with a hand saw. Cleaned it up with a block plane.
Google "table saw taper jig" and you'll see lots of home made and inexpensive commercial designs. I used a commercial design similar to this that had graduations to set the angle.
I just finished sanding the top rim, and the resultant angle was just about 1.5 degrees.
If you make your own jig, you can easily draw the angle on paper using a bit of trig.
Mitch
Mitch
