www.KitGuitarsForum.com
It is currently Sat Oct 20, 2018 12:12 pm
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Sat Mar 04, 2017 12:07 pm
Offline
Hello,
I'm building a 12 string for a friend and plan to use Sitka and Indian Rosewood. I have a general question regarding top thicknessing and bracing. Depending on the stiffness, what do you suggest for top thickness parameters? Also, bracing pattern options and dimensions? Thanks.
Boyd Moon
Top
 Profile
PostPosted: Sat Mar 04, 2017 12:29 pm
Offline
I build a 12 string using my 6 string body plans. I had to modify the headstock design to put in the extra tuners. My bracing pattern was the same pattern I used for a 6 string. I did make them just a touch taller. +1 mm. My top thickness was calculated the same way I do six string guitars. Generally falling between 2.5 mm to 2.8 mm.
There are 12 string guitar plans you can buy on line. I think they are worth it for a first 12 string as they help with a lot of new measurements over a 6 string.
_________________
Top
 Profile
PostPosted: Thu Mar 09, 2017 9:31 pm
Offline
The only thing I do is a larger plate and an extra tone bar
_________________
Top
 Profile
Who is online
Jump to:
cron
