Abalone Purfling around sound hole- What glue?
Stuart
Total Topics: 38
Decided to start the top as I'm wiating for the replacement back strip from Martin. I'm neding to glue in the Abalone Purfling around the sound hole before I put on the top bracing. What kind of glue can I use? I know that super glue would work but it doesn't give me a lot of time to set the thing. Epoxy would probly work and then there's the old standby of Titebond, which would give me plenty of time to make sur that the ends of the purfling met but would take longer to dry. Any ideas?
Aug 29, 06 | 7:57 am
Stuart
Total Topics: 38
Sorry about the typos. I guess that I should "preview my post"
Aug 29, 06 | 8:35 am
jhowell
Total Topics: 37
Stuart--
I think that a lot of people that use super glue do it by putting all of the abalone in the channel and then they 'wick' thin super glue around the edges by using a tooth pick or wire to place a small drop here and there.
From my scale modeling days, I can say, "Do not try to put drops directly from the bottle!!"
Cut offs from changing guitar strings work well for this. I've found that the best is the wound G string. And now that I've opened the door...
Aug 29, 06 | 2:20 pm
Ken Cierp
Total Topics: 58
I think CA is a good choice for inlay including pearl -- Tower Hobbies and other RC suppliers sell neat wisker applicators that lay a very fine bead of glue.
www.kennethmichaelguitars.com
Aug 29, 06 | 2:31 pm
Stuart
Total Topics: 38
Well, I hope that I didn't screw things up. I was reading the StewMac insructions and they used Titebond, so I decided to go with that. It was only AFTER I was finished and had the thing clamped hard that I realized the StewMAc directions were for a rosette. Oops! Am I screwed? I'm letting it dry overnight and my plan is to give it a light sand in the moring and see how it looks? Do you think that it will work????? Damn!
Aug 29, 06 | 3:11 pm
Ken Cierp
Total Topics: 58
Tite bond will be just fine --- The reason I personally like CA is that it does not cause the wood to swell like Titebond (waterbased). Sometimes that can be a problem when installing a Rosette, those delicate top grooves can puff up in a hurry. If everything fits you did good!
Aug 29, 06 | 3:28 pm
ejko
Total Topics: 25
I used LMI White Glue for my abalone rosette and it worked out fine.
Aug 29, 06 | 4:43 pm
Stuart
Total Topics: 38
Well, I sanded it down today and it looks fine. As a new builder, it seems that every task is either a recipe for redemption or distruction. but.....So far so good. Thanks for all your help. This web site is a blessing!
Aug 30, 06 | 5:21 pm
