lacquer sticks and tru-oil
pfox3
Total Topics: 3
after much sweat and many tears, I have my neck in a good place, except that there is a gap between the heel and the box on the bottom side along the center.
Has anyone ever used lacquer sticks to fill a gap like this, (about .015 to .020) and then finished with Tru-oil?
I also have never used the sticks and wonder how I'd get it in the crack at 90 degrees and not smear.
Thanks!
Paul
Aug 04, 06 | 12:49 pm
jhowell
Total Topics: 37
Can you post a picture of where the gap is?
Aug 04, 06 | 3:18 pm
ejko
Total Topics: 25
Minwax makes a non-hardening wood filler that comes in a variety of colors. I used it to fill the few gaps that were between the wings of the neck and the side of the guitar. I made a pencil thin line of filler along the entire distance, and then finished over it with TruOil. It came out great.
Aug 04, 06 | 3:35 pm
pfox3
Total Topics: 3
jhowell, I won't be able to post a pic for a bit due to camera issues!
ejko, it is between the wing and side, about 1/3 the distance in from the back and only about 3/4 long. When you mention the non-hardening type, what does that mean? DOesn't it need to eventually harden to be able to be finished over?
Thanks,
Paul
Aug 05, 06 | 8:55 am
ejko
Total Topics: 25
I chose the non-hardening so that the neck could be reset if need be at some future point. I was concerned the hardening type would act as an adhesive.
The gap you describe sounds about the same as the one I had. The filler I used is not a perfect match, so by just filling the gap, it stands out. That's why I put a very thin line of it along the entire interface. The line is about the width of a pencil point. The Tru-Oil went right over it without a problem.
Aug 05, 06 | 11:21 am
