A question on humidity?
dcbaisden
Total Topics: 25
Did not want to hijack dviss thread.
what about moisture content and humidity?
do any of you use a moisture content meter?
are the little $20 moisture checkers very accurate?
http://cgi.ebay.com/HQRP-Digital-Wood-Moisture-Meter-Tester-4-PIN-w-LCD-OKN-/350299207231?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item518f75b63f
The humidity here in northeast Ohio has been in the 80 and 90% range.
I have all the braces glued on the top and its been setting for days waiting so I can get the humidity down below 60%.
Any comments greatly appriciated.
Dave
Jul 01, 10 | 7:40 am
Total Topics: 52
I watch my RH level more than relying on these. This is ok for large pieces but will not work of thinner luthier stock
Blues Creek Guitars Inc.
Athorized CF Martin Repair Center
Jul 01, 10 | 8:22 am
Freeman
Total Topics: 27
After this experience
http://www.kitguitarsforum.com/forum/threads.php?id=2673_0_2_0_C
I monitor the humidity in both my shop while building and in my house (particularly during the winter when it tends to be very low). I use one of the cheap little PlantetWave RH meters sold at guitar stores and just check the RH of the air.
You can calibrate by putting the meter in a baggie with a small container of salt and water - a super saturated salt water mixture will have a RH of 75%.
http://exoticpets.about.com/od/herpresources/ss/hygrometer_8.htm
Jul 01, 10 | 8:24 am
dcbaisden
Total Topics: 25
Thanks John.. Freeman. how long do you give the wood to adjust to the current humidity? I have a sling meter made by amprobe. its very accurate.
Today it 56% in my garage and I can get it down another 5 to 10% by running the ac. the humidity should be low for the next 3 to 4 days?
Dave
Jul 01, 10 | 8:37 am
Total Topics: 52
It depends on the wood species and thickness. If it was kiln dried a few days should be fine but always err to the side of caution. I keep my shop 45%.
Jul 01, 10 | 4:19 pm
dcbaisden
Total Topics: 25
Thanks John,, Freeman thanks for the links, checked my meter and it was 3% diffrent.
Finally got the top glued on and flush routed.
I started the grain filling on the back today and will finish that off tonight and do the stain. these rebuilds are hard on the brain.
Dave
Jul 04, 10 | 2:15 pm
