Fret slot clean up
After gluing on the binding, I ran some 0000 steel wool over the ebony fretboard. So of course I had glue and steel shavings in the fret slots. There are no doubt better ways than this to clean them out, but it's what I had on hand. The magnet pulls the steel wool out, the little Stanley saw blade slips along the bottom of the fret slot and cleans 'em up.
Dave B
Jun 28, 10 | 2:39 pm
Total Topics: 52
I found an exacto blade works well for this also. it is amazing how resourceful we can be when we have to.
Blues Creek Guitars Inc.
Jun 28, 10 | 3:10 pm
enalnitram (Martin Lane)
Total Topics: 47
i like to use nut files.
Jun 29, 10 | 5:30 am
Nut files are a good ideaa! In my case, the fb binding was already attached, so I could not run a file straight thru the slot.
Dave B
Jun 29, 10 | 5:53 am
Total Topics: 47
you can't run a file straight thru the slot on a bound board, but you can't run a saw thru it either. you can use the tip of the file, and needle files tend to have a little angle tip that will get you much of the way there.
lots of stuff will work, though.
Jun 29, 10 | 9:44 am
Actually I don't run the saw thru it. I put the flat end of the saw flat into the slot. Then move from side to side, when I hit a clump of glue the teeth pick it out really quick.
Dave B
Thanks for the input Martin!
Jun 29, 10 | 9:58 am
