when to close the box - humidity question
dviss
Total Topics: 18
I've been waiting for a few weeks to close the box - humidity here in Wisconsin is high and I haven't seen my hydrometer under 65 for the last month (in the un-finished, dry basement where I have my work bench set up.)
Do I just wait it out or is there something I can do to dry things out? The top and bottom plates are too oversized to fit in a case - that was my first thought on how to regulate the humidity. (after they are glued and trimmed flush is a different story)
I've been looking at all the regular places for a rubbermaid style container but haven't found one large enough to fit the top and back in, that really snaps shut - the tops on the larger containers all fit kind of loose. So it doesn't seem like that would help much.
I don't have a de-humidifyer - I'd get one but I think it'd be futile to run it in the basement - the area is just too large.
So what's a guy to do? I want to keep moving on this thing!
May 29, 10 | 10:16 am
Total Topics: 52
Closing the box isn't that critical , it is when the braces are glued on. The RH will influence the bracing and plate. That is what causes the movement. The closed box , doesn't matter that much. Try and keep your RH between 40 and 55% and you will be fine
Blues Creek Guitars Inc.
May 29, 10 | 11:15 am
dviss
Total Topics: 18
Thanks for the insight John,
Does the interaction with the x brace and the sides (assuming the x is tucked in the kerfing/lining) not affect the top radius? In my mind it did, but I've been completely wrong before. :)
So I should close up the box, get the RH back down to the mid 40s, and the top radius will be back to the intended height?
May 30, 10 | 5:50 am
Total Topics: 52
the relationship of the top and the braces will influence the top radius during RH swings. The wetter the more arch , and dryer it will flatten or sink.. the kerfing has no influence in that.
May 30, 10 | 9:46 am
dviss
Total Topics: 18
Thanks John, just what I needed to hear... onward and upward then.
May 30, 10 | 10:52 am
