Soundbaord wood question about pitch (wood resin)
Jerry
Total Topics: 3
Hi all,
Do any of you have tips/information about how to deal with soundboard wood that has streaks of pitch on the surface?
I received a set of P.O.Cedar to use for the top of my SM 000 kit guitar, and it has quite a few streaks of sticky pitch on the surfaces.
1. Is this common, and should I have expected this possibility?
2. If it is common how would I deal with it, or should I even try to?
I have not been able to find any discussions about this issue, so I'm hoping someone here can help me out.
It was rather pricey, and I don't know how to go about working with it.
Thanks. JC
Apr 19, 10 | 6:34 pm
Try acetone, or another solvent to remove the pitch. Let it sit for a bit and see if more oozes out. Are these actual pitch pockets, or just sticky residue? I have had pitch pockets that I have had to be very strategic with...they are empty of the pitch, but still leave a cavity. They are seldome deeper than 1/8", so when I am thickness sanding 1/4" stock, I may decide which side gets thicknessed based on the pocket. It may distort the bookmatch a little this way, but I'm no pro, and its a more efficient use of wood others might not use.
If it is just a residue, again...try using a solvent to wipe it off.
Apr 20, 10 | 10:04 am
Ken Cierp
Total Topics: 58
If this is supposed to be a high quality top and there are pitch "pockets" --- that's a defect found on "B" quality Cedar soundboards. It should be replaced.
Apr 20, 10 | 5:13 pm
Total Topics: 52
Contact your supplier for a return. Do not apply anything to it until you hear from them> SM is a good company and will most likely replace it
Blues Creek Guitars Inc.
Member Board of Directors ASIA
Apr 23, 10 | 8:48 am
Jerry
Total Topics: 3
Thanks for the feedback. I called today for a replacement, and there will be no problem. Couldn't have went better on the phone, and should be quickly resolved.
Thanks again. JC
Apr 26, 10 | 6:05 pm
