Marking sides to accept back braces
TJB
Total Topics: 10
Hi, I've been so long away from building that it feels like I'm starting from scratch. I have a stewmac 000 with the top glued on and now I need to mark the sides to cut rebates to accept the back bracing.
The instructions are very clear about keeping the body length accurate and matching the back exactly to that length and therein lies my problem (possibly just in my head!). If I lightly clamp the back at the head and tail blocks, with the braces proud of the sides (as they must be before the rebates are cut) then I must be inducing over-bend in the back so my pencilled back length measurements cannot line up with the body length.
Is this a problem? It seems to me that I will be marking my rebates progressively out of position as I move towards the tail block.
All help gratefully received!
Regards,
Tim
Nov 27, 09 | 3:57 pm
TJB
Total Topics: 10
Sometimes the very act of writing something down makes it clearer. I've been back to the workshop and successfully marked my rebates. Too much thinking going on here.
Tim
Nov 27, 09 | 7:23 pm
Hey Tim -- glad you're back to building! Keep us abreast of the build --
Nov 28, 09 | 4:41 am
TJB
Total Topics: 10
Thanks Bill!
I got the back fitted but not glued last night so this morning I took the mold out, cleaned up the inside and cut the side reinforcement strips. Can't glue them at the moment because the RH has dropped to 35%. Ironic really - I'm usually bleating on about the humidity being too high!
Tim
Nov 28, 09 | 2:35 pm
Running Dog
Total Topics: 1
Next time, whether you glue the top or back first, mark BOTH edges for ALL the braces (and mark the braces, too, for length) before gluing EITHER plate. It's infinitely easier to have everything trimmed and fitting while you still have access the inside of the rim. It took me several guitars to learn this ...
Rick
Nov 30, 09 | 8:34 am
TJB
Total Topics: 10
Rick, that sounds like a great idea. Hope I remember it next time when I definitely won't be using the using the internal cardboard mold/waist clamp method. I got the back glued on this afternoon but it was a bit like herding cats - every time I got something in the right place something else would have moved out of position. Fingers crossed for when I take the clamps off!
Tim
Dec 05, 09 | 11:39 pm
