A simple set up for applying a brush on Finish
Ken Cierp
Total Topics: 58
This set up allows you to flip the guitar body with one hand if you grab it in the sound hole with your thumb on the FB extension masked area. I found that using the corner of a bench increases the open space around the guitar. The measurements for the clamping details will be available in the on-line KMG "Success Kit" manual.
Dec 05, 08 | 5:24 am
FredB
Total Topics: 11
I'm still waiting to apply finish but am not satisfied with my practice. This is a solution to the very thing I wanted in place before I started applying finish. Thanks
FredB
Dec 05, 08 | 6:05 pm
jeremy3220
What do you use to adhere the threaded inserts? Epoxy, or is the outside threaded too?
Dec 05, 08 | 7:52 pm
Ken Cierp
Total Topics: 58
The inserts are threaded inside and out.
Dec 08, 08 | 7:57 am
nehsgolfer
Total Topics: 4
Ken, or anyone else for that matter, can you give me device/method for holding the neck while working on it?
Harold
Jan 05, 10 | 5:48 am
Ken Cierp
Total Topics: 58
The KMG necks all have brass inserts in the tenon --- any comfortable shaped handle can be fabbed and bolted to the neck with a 1/4-20 bolt. If you buy one of the EBay, Martin rejects the hole should be there to install a the brass insert --- use the course thread type, the fine thread inserts are too large and will surely split the tenon.
Jan 05, 10 | 6:28 am
Dennis Weatherly
Total Topics: 73
Nice idea, Ken! My 000 has a dovetail neck joint and I wanted to do something similar for brushing on the finish. I came up with a rotisserie sort of arrangement using 1/4-20 threaded rod. I drilled a 1/4" hole thorugh the heel block and a 1/2" hole through the end block (it will get a pickup jack when the guitar is finished). The rod has a washer and nut on each side of the heel block. The end at the end block was built up with masking tape to make a snug fit in the hole. I can easily rotate it any which way while applying the finish.
http://picasaweb.google.com/lh/photo/_yztB6FBDMu_2aNAM4aFFg?authkey=Gv1sRgCOSZxePOjdaBOg&feat=directlink
Jan 05, 10 | 10:01 pm
nehsgolfer
Total Topics: 4
Dennis, I really like the color of the top of your guitar. How did you get it ?
Harold
Jan 06, 10 | 5:07 am
Ken Cierp
Total Topics: 58
Dennis,
Very clever! Do you have stops on the rod to hold the body is a fixed postion?
Harold,
Here's the Martin factory neck fixture
Jan 06, 10 | 5:15 am
Dennis Weatherly
Total Topics: 73
I didn't put any stops in this version, and I wish I had. The next version will probably have a 1/4" hole in one of the uprights rather than the V-notch, and a 1/4-20 knob or wing nut on the rod. Then I can quickly snug that down to hold the body in any position.
For now, I use the built in stops on my left hand to carefully hold the body in position as I brush :-)
Jan 06, 10 | 6:23 am
Dennis Weatherly
Total Topics: 73
The top is Sitka Spruce and the color comes from 3 coats of Target UltraSeal amber shellac. There is no toner or other coloration - just the amber shellac itself. I applied it carefully using a DaVinci #50 brush to keep the coloration even. Over the UltraSeal I am brushing Target EM6000 lacquer, which is water clear. There are four coats on it in that picture.
Jan 06, 10 | 6:26 am
