Should I unglue?
gouzos
Total Topics: 22
I don't think I got the sides-headblock joint as perfect as I should.
The sides contact each other perfectly but one is just a hair higher that the other (less than 1mm)
Also I didn't get squeeze-out everywhere. What do you think I should do?
If I have to separate it, how do I do that?
May 15, 08 | 5:50 am
If the only problem is that one side is slightly high by that small amount, I would say to proceed, as long as the neckblock isn't tilted to one side or the other. As for lack of squeeze-out everywhere, you are probably okay -- tough to say for sure.
May 15, 08 | 5:59 am
gouzos
Total Topics: 22
On the back (the continuous one) the glue is fine.
On the front side (the one with the dovetail pocket) on on side of the mortise I don't see squeeze out.
May 15, 08 | 6:11 am
gouzos
Total Topics: 22
That plus the fact that I forgot to acetone wipe that side kind of worries me, even though the joint seems strong.
May 15, 08 | 6:15 am
Doesn't sound like it should be a problem. Squeeze out is not really necessary, and too much squeeze out can indicate a weak joint just as not enough glue can make for a weak joint.
The wiping with acetone is not a worry. It is only a measre to take if the wood you're using has a lot of natural oils on the surface. The Indian rosewood we usually get has been dried and bent and doesn't have surface oils that present a problem.
May 15, 08 | 6:29 am
gouzos
Total Topics: 22
Thanks.
I will carry on and hope it won't be a problem.
May 15, 08 | 6:32 am
Ted
Total Topics: 22
Gouzos - When I first glued sides to blocks, I had no idea what "squueze out" was. It certainly sounds like you are doing fine! I would be happy if the issues on my builds were desribed in words like "<1mm" or "a hair higher"
May 15, 08 | 7:47 am
jeremy3220
I wonder if there is even a great deal of stress put on that joint. The neck will be acting to hold it there and you'll have the top and back holding it there also.
May 15, 08 | 6:41 pm
