Reverse Kerfing
John B
Total Topics: 15
When using the reverse kerfing method, do you need different kerfing or can standard kerfing be used either way? I know LMI sells "reverse" kerfing but if I already have standard stuff, can it be used successfully reversed?
Thanks,
John Butler
Mar 01, 08 | 5:11 am
John -- if you look at the standard kerfed lining, you'll see that if the kerfed side was glued to the rim, the angle would fall down, away from the rim into the body. Impossible to just reverse it.
Mar 01, 08 | 5:23 am
Ken Cierp
Total Topics: 58
Here's a little info about RR kerfing
http://www.kennethmichaelguitars.com/REVERSEKERFING.html
Mar 01, 08 | 11:03 am
davidmor
Reverse kerfed linings are a different animal from standard linings. I prefer them as they make the sides a lot stiffer and they look much nicer. Before trying to use it though, do a little searching about it. They need to be pre-bent or wet so they don't crack. It isn't hard, but it is a different method. I personally pre-bend them but others wet them to get them to form without snapping.
My Blog
Mar 02, 08 | 6:45 pm
FredB
Total Topics: 11
My kit uses reverse rounded kerfing and does give a very nice look. As Ken's link shows and David states, it is a very easy task to pre-bend the pieces. It just adds a little time to the project.
Mar 03, 08 | 12:47 pm
