Recommendations for Neck Stain
ejko
Total Topics: 24
I'm building my first, a Rosewood/Sitka OM. Any suggestions on stain for the mahogany neck so that it compliments the rosewood back/sides?
Does anyone ever not stain the neck?
Thanks!
ejko
Apr 13, 06 | 2:06 pm
Ed -- I just put a finish on the neck without a stain ... Since the neck doesn't have to be "resonant" in the same sense as the body, a soaking stain wouldn't be a problem. I was looking at stains at Home Depot the other day -- lots to choose from.
I'm looking for a stain for the mahogany sides of my Martin Jumbo kit; almost to the staining point.
Apr 22, 06 | 5:41 am
CrowDuck
Total Topics: 25
I've been thinking about trying a 'sunburst' stain on a neck. Hoping I can achieve the affect by staining dark, then either wiping or sanding back to natural wood. Time to experiment on some scrap.
CrowDuck
Apr 23, 06 | 2:03 pm
When I finish my Les Dragon, I will do a sunburst on the neck. I am going to leave the bulk of the neck as natural, and then spray towards the head and the heel with a very dark cherry red. SHould look interesting, with an ebony heel plate.
Ejko, I did my rosewood jumbo as a natural, and it compliments it beautifully. You could also try stew-macs mahogany red, maybe mixed with a little vintage amber to brown it up.
May 04, 06 | 12:13 pm
Total Topics: 52
The best way to make the neck look like the rosewood I learned from CF Martin. I stain the mahogany neck with ebony first , then I lightly sand this. Seal the neck and fill with a dark walnut filler. Once that is cured I seal and lacquer.
This will get you a good result. I use satin on all my necks
john hall
blues creek guitars
May 23, 06 | 4:18 pm
ejko
Total Topics: 25
John Hall,
Do you use the same filler for the rosewood body? What brand?
Thanks!
Jul 05, 06 | 5:23 pm
ejko
Total Topics: 25
John Hill,
Ignore my last question. I found the answer in one of your other posts.
Jul 06, 06 | 4:43 pm
ejko
Total Topics: 25
Completed the neck using the method John Hall described above (except used True Oil instead of lacquer). The color came out great, and matches quite well with the rosewood. Thanks, John!
Jul 16, 06 | 8:05 am
